Discussion topic: CABLE SCREW IN LEAD THAT GOES TO THE TV NOT DISH
Message posted on 02 Dec 2024 10:13 AM
When we are watching cinema our tv pixels ..It doesnt happen on any other channel ... any Ideas ? thanks
Message posted on 02 Dec 2024 10:55 AM
Re: CABLE SCREW IN LEAD THAT GOES TO THE TV NOT DISH
Not sure of the relevance of the title?
However, such issues are usually because of dish alignment - the movie channels seem most susceptible to small alignment issues.
Message posted on 02 Dec 2024 01:07 PM
We think it's the cable, the dish hadn't moved at all
Message posted on 02 Dec 2024 01:12 PM - last edited: 02 Dec 2024 01:12 PM
A misalignment affecting only some channels would not be visible: it's millimetres of difference.
Message posted on 02 Dec 2024 01:18 PM
Hi @lulu2004 Dish or cable, it doesn't matter. It sounds like you need to contact Sky to arrange for an installer to check your setup. How do you know that your satellite hasn't moved? If the cable was damaged, it would effect all channels.
Message posted on 02 Dec 2024 01:32 PM
Ok we will d that, the reason I thought it might be the cable that screws into the box then Hdml into the tv, when I play around with it it stops
Message posted on 02 Dec 2024 03:00 PM
@lulu2004 wrote:Ok we will d that, the reason I thought it might be the cable that screws into the box then Hdml into the tv, when I play around with it it stops
So wiggling the HDMI connectors resolves it?
It may be the lead or the connectors have been 'damaged'. It's possible the sockets are faulty but are usually quite robust.
If it's the Sky end then they may consider replacing the box but worth trying a new lead first?
Message posted on 02 Dec 2024 03:58 PM
Ok thanks
