Discussion topic: CABLE SCREW IN LEAD THAT GOES TO THE TV NOT DISH
This message was authored by: lulu2004
When we are watching cinema our tv pixels ..It doesnt happen on any other channel ... any Ideas ? thanks
Re: CABLE SCREW IN LEAD THAT GOES TO THE TV NOT DISH
Not sure of the relevance of the title?
However, such issues are usually because of dish alignment - the movie channels seem most susceptible to small alignment issues.
Avatar for lulu2004
We think it's the cable, the dish hadn't moved at all
@lulu2004
 A misalignment affecting only some channels would not be visible: it's millimetres of difference.
Hi @lulu2004   Dish or cable, it doesn't matter. It sounds like you need to contact Sky to arrange for an installer to check your setup. How do you know that your satellite hasn't moved? If the cable was damaged, it would effect all channels.
Avatar for lulu2004
Ok we will d that, the reason I thought it might be the cable that screws into the box then Hdml into the tv, when I play around with it it stops
So wiggling the HDMI connectors resolves it?
It may be the lead or the connectors have been 'damaged'.  It's possible the sockets are faulty but are usually quite robust.
If it's the Sky end then they may consider replacing the box but worth trying a new lead first?
Avatar for lulu2004
Ok thanks
