Discussion topic: Builders removed my satelite dish and now i have no signal.
Message posted on 24 Jun 2024 11:26 AM
Semi-detached house. Next door's builders removed my dish while i was away.
The app says my signal is fine but my TV says there is no sayelite signal.
How do i rectify?
Message posted on 24 Jun 2024 11:30 AM
Re: Builders removed my satelite dish and now i have no signal.
You will need to call Sky to request they put the dish back up presuming it hasn't been stolen. Sky could potentially charge you for this (around £65). Not sure why builders working next door have removed your property. If it was me I'd be passing any charges in their direction.
Message posted on 24 Jun 2024 04:11 PM
It was on the join between our houses and in the way of the re-rendering & roofing work. Does anyone have a working/current number for Sky?
Message posted on 24 Jun 2024 04:13 PM
@JuiceTank You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 24 Jun 2024 09:42 PM
Perfect. Very helpful. Thanks very much @GD1
