Broken cables
Runner
Post 1 of 15
Broken cables
My cables have been cut in two. Can they be joined back together?
Camera Operator
Post 2 of 15
Re: Broken cables
Which cables ??
Runner
Post 3 of 15
Re: Broken cables
The dish cables outside
Executive Producer
Post 4 of 15
Re: Broken cables
If you mean the cables from the dish it would be better to run new cables to be honest
BT Ultra Infinity. Apple Time Capsule. Sky Q 2TB watching UHD through a LG OLED55B7 and listening through a soundbox. Multiroom with 2 miniboxes
Runner
Post 5 of 15
Re: Broken cables
Thank you. That’s the plan.
But can it be done for a temporary fix?
Oracle
Post 6 of 15
Re: Broken cables
@Carlyjones
If the cut is external to the building, I would suggest replacement is more suitable. If internal, you could try fitting an f-plug to each of the four cut ends, and then use two f-to-f junctions.  This will add attenuation to the cable run, though.
Sky Q from April 2016 (Silver & 1 Mini, both over ethernet), BT ADSL (14Mbs), BT Home Hub 6 (ethernet), Lenovo Tab 2 A7 (Android 4.4 KitKat), Wileyfox Swift (Android 7.1.2 Nougat), LG 49UJ701V with Yamaha RX-V375, Toshiba 32L6353, Samsung UE22F5400
Runner
Post 7 of 15
Re: Broken cables
My electrician has just arrived and he has joined the wires but still no signal
Oracle
Post 8 of 15
Re: Broken cables
Have you restarted your Sky box? Switch it off at the wall for 30 seconds.
Oracle
Post 9 of 15
Re: Broken cables
The tricky bit is you need to splice both the internal copper core and the external steel braid, without them contacting each other. Not impossible, but certainly fiddly without using cable fittings.
https://www.bestcablesplitter.com/how-to-splice-coaxial-cable/
Remember that there is a voltage coming up the cable from the Sky box, so unplugging this from the mains is a must.
Runner
Post 10 of 15
Re: Broken cables
Hi,
yes ive tried that, still says no satellite signal also my catch up tv doesnt work so I can’t watch anything
Executive Producer
Post 11 of 15
Re: Broken cables
@Carlyjones wrote:
Hi,
Sky box needs a satellite signal to work.
Is he using proper F type connectors  as suggested above?
Oracle
Post 12 of 15
Re: Broken cables
If your electrician is just twisting the wires together, it's unlikely to work reliably.
Editor
Post 13 of 15
Re: Broken cables
Could you post a photograph of the cable repair method that your electrician has adopted, in order to provide us with enough information to advise you further.
Godfrey.
Runner
Post 14 of 15
Re: Broken cables
He has got any other the f adapters suggested so we gonna try and get some on Monday.
More replace the entire cable
Oracle
Post 15 of 15
Re: Broken cables
@Carlyjones
When I faced a similar situation, I found my local hardware store stocked 'satellite extension leads' and 'satellite wall plates'. After a quick bit of surgery,  two extension leads provided four f-plugs, and one wall plate provided two f-junctions.
