Discussion topic: Broadband wont connect to sky box
This message was authored by: KirstM123
My Sky Q Box is not connecting to my Sky Broadband WiFi after numerous attempts of restarting and resetting the sky box, and router please advise what can be done to fix this problem
Re: Broadband wont connect to sky box
Hi @KirstM123
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Avatar for KirstM123
Thank you I've tried this and it didn't work 😩
Hi @KirstM123
Exactly what happened when you carried out the Network reset on the Q box?
It says unable to connect to network
