Discussion topic: Broadband not connecting to sky Q box
Message posted on 26 Mar 2025 01:28 PM
Re: Broadband not connecting to sky Q box
Yes mate both frequencies disabled
Message posted on 26 Mar 2025 02:02 PM - last edited: 26 Mar 2025 02:10 PM
@Birchy23 wrote:
This will never be resolved until they recall all the boxes and replace them with o solution that works. End of!!!
As repeated above, Q has been around for nine years in millions of homes: it's absolutely not going to be recalled, and 'replacement' will be by Glass/Stream (or a successor online-only Sky product) before satellite television broadcasting to the UK & RoI ends around the turn of the decade.
Message posted on 26 Mar 2025 05:55 PM
@Birchy23 wrote:Yes mate both frequencies disabled
And you've been back and checked? It has a habit of turning them back on.
Message posted on 04 Dec 2025 07:43 PM
This happened to me with my sky q box and range max router
Simple solution settings/network/another broadband supplier select your sky router and key in pass code and you are good to go (source My Sky)
