Discussion topic: Broadband not connecting to sky Q box
Message posted on 06 Jan 2024 10:51 AM
							Re: Broadband not connecting to sky Q box
Go on the website and report a problem that needs an engineer
Message posted on 06 Jan 2024 11:15 AM
Will try that again but its not giving me that option 🙈
Message posted on 13 Jan 2024 07:03 PM
Got my Sky Max Wifi Hub today. It set-up ok, and i got connected to everything on wi-fi , but not to my Sky Q box. tried umpteen times , but keep getting message that it was unsuccesful. Held WEP button for more than 2 minutes a few times, did not make any difference. Followed guide info to the letter. It does say i may need a Sky Q booster. Crap, my Q box is less than 4 metres away from HUB just other side of plasteboard wall. Looks like i will have to call someone for help. For the record, my original sky q hub i got with the sky q box 3 or 4 years ago worked fine and connected fine.
Message posted on 13 Jan 2024 08:36 PM - last edited: 13 Jan 2024 08:38 PM
You mean WPS? It should connect through that wall ok. You did a full network reset on the Q?
Message posted on 13 Jan 2024 09:00 PM
I just did a full reset on my Q Box and it still will not connect to my broadband.
Message posted on 13 Jan 2024 09:02 PM
I bought the tp link power line WiFi extender TL WPA7517 which solved this problem (wife and kids couldn't wait for sky to come out!) but this slows down the connection to the sky q box- long term solution is hard wiring in the sky q box which is my next action
Message posted on 13 Jan 2024 09:03 PM
I even tried deleting my saved programmes, and rebooting Sky Max hub, which is new today.
Message posted on 13 Jan 2024 09:04 PM
I may go down that road, ethernet is always better than wifi connection.
Message posted on 13 Jan 2024 09:06 PM
@GeoWolf58 wrote:I just did a full reset on my Q Box and it still will not connect to my broadband.
Mini boxes are turned off when you're doing this?
Message posted on 13 Jan 2024 09:10 PM
The tp link option did work because you can connect your sky q box to the power line socket with an Ethernet cable which stopped the signal breaking, I spoke to the tech guys at curry's pc world and they said that worked much better than WiFi extenders because they can only boost whatever signal is their. The issue with it is speed though- I have full fibre 150mbps and I only get 80mbps through the powerline
Message posted on 13 Jan 2024 09:13 PM
@Skywifimadness wrote:The tp link option did work because you can connect your sky q box to the power line socket with an Ethernet cable which stopped the signal breaking, I spoke to the tech guys at curry's pc world and they said that worked much better than WiFi extenders because they can only boost whatever signal is their. The issue with it is speed though- I have full fibre 150mbps and I only get 80mbps through the powerline
While I agree that powerline is better the idea that "they can only boost whatever signal is there" is classic PC World nonsense. The point is the extender sits within a decent strength range of the router and then re-broadcasts the signal (and vice versa with device to router comms) like a relay. So it extends the area over which a device can find a wifi signal.
Message posted on 13 Jan 2024 10:27 PM
no mini boxes or boosters
Message posted on 13 Jan 2024 10:29 PM
Decided. I go get Ethernet cable tomorrow and hard wire my connection between Sky Q box and Sky Max hub. Should solve the problem , full stop.
Message posted on 13 Jan 2024 10:38 PM
Disable wifi too 🙂
Message posted on 14 Jan 2024 01:07 PM
Problem sorted. I bought an Ethernet Cat6 cable at Curry's this morning and installed it between my Sky Max Hub and my Sky Q Box. Everything is working fine now. Used the simple instructions i got online from Sky Help. You need to disable the 2.4Ghz and 5Ghz wireless ( only if you are not connecting mini boxes using Wi-Fi ).
