Discussion topic: Broadband not connecting to sky Q box
Message posted on 28 Nov 2023 09:00 PM
							Re: Broadband not connecting to sky Q box
@NS12 wrote:This is driving me mad!!
tried all of the above, managed to get it to connect via hotspot but then when tried advanced settings as suggested back to getting the unsuccessful connection message again.....Any other help gratefully received!
Tries the reset button on your router? Not the power button.
Message posted on 28 Nov 2023 09:04 PM
Yes I've tried the rest button on the router too!
Message posted on 28 Nov 2023 09:39 PM
Try a booster maybe. Would need to get it from Sky (or buy something like this
https://www.currys.co.uk/products/tplink-re200-wifi-range-extender-ac-750-dualband-10024654.html
@Gaz1 said he has got a stable connection using a v1 of this extender, don't know how you make sure you get a v1 (there are 5 revs of the hardware) or if v2-v5 also work just as well.
Message posted on 29 Nov 2023 06:37 PM
Have now tried all suggested options (many thanks to all members for their suggestions) however nothing has worked . Can someone from Sky please response to advise how this issue should be resolved/progressed?
Message posted on 01 Dec 2023 02:42 PM
I'm also having this issue. Have tried unplugging, resetting and hot spotting.
can not get my second Sky q box to work.
so frustrating.
Message posted on 01 Dec 2023 03:12 PM
The fact that no one from sky is responding to this long list of unsatisfied customers is pretty pathetic.
one way I tried that seemed to work is doing a reset of the router using the rest button then resetting the mini boxes as if you were installing them again for the first time. It's a right ballsche as you even need to re-sync the remote but it worked for me
Message posted on 01 Dec 2023 05:20 PM
Had to get an engineer out yesterday, who finally after 45 mins managed to fix it!
New parts were need, so it maybe your only option if like mine nothing else worked!
Message posted on 01 Dec 2023 06:22 PM
@NS12 wrote:Had to get an engineer out yesterday, who finally after 45 mins managed to fix it!
What sort of new parts?
Message posted on 05 Dec 2023 05:37 PM
Having exactly the same issues as everyone else, was working fine this morning, went to watch at lunch time and hey presto, no connection to router, tried multiple times, resetting both sky q box and router, nothing, it is absolutely ridiculous!!
Message posted on 05 Dec 2023 06:29 PM
@Paul+O+1976 wrote:Having exactly the same issues as everyone else, was working fine this morning, went to watch at lunch time and hey presto, no connection to router, tried multiple times, resetting both sky q box and router, nothing, it is absolutely ridiculous!!
Did you try the reset button on the router rather than the power? Supposedly has worked better for some people who are on Sky BB.
Message posted on 05 Dec 2023 06:51 PM
Finally got through to a Sky Engineer, he asked me to unplug router and all cables, leave it 8 minutes, was then told to reconnect only the power, wait for it to power up and for the green wifi led to turn on, then tried reconnecting the Sky Q box using WPS, reconnected successfully, then plugged the internet cable back in, Sky Q box then also reconnected to internet once fully connected on router.
Will have to remember this for next time!!
Message posted on 05 Dec 2023 09:23 PM
@Paul+O+1976 wrote:Finally got through to a Sky Engineer, he asked me to unplug router and all cables, leave it 8 minutes, was then told to reconnect only the power, wait for it to power up and for the green wifi led to turn on, then tried reconnecting the Sky Q box using WPS, reconnected successfully, then plugged the internet cable back in, Sky Q box then also reconnected to internet once fully connected on router.
Bizarre! Thanks for sharing.
Message posted on 07 Dec 2023 08:52 PM
I'm having this same issue!!
been trying for over a week now to try and sort it.
Tried turning off the sky box, turning off the router, even did a factory reset 😩
Tried connecting to a hotspot and resetting the network - nothing works!
the broadband connects to everything except the sky box and the sky box will connect to hotspots but not the sky broadband! Think I'm gonna have to phone for an engineer... 😒
Message posted on 07 Dec 2023 09:17 PM
Even tried this solution and it still won't connect 🙈
Message posted on 07 Dec 2023 09:48 PM
Did the engineer resolve it ? And did they say what was wrong?
