Discussion topic: Broadband not connecting to sky Q box
Message posted on 20 Sep 2023 08:03 PM
Sky broadband went down last night, wifi now up and running but broadband not connecting to Sky Q box so no apps able to work and sky mini box cannot work. Any suggestions I've followed the steps through settings and trying to reconnect the router that way but no joy
Message posted on 20 Sep 2023 08:07 PM
							Re: Broadband not connecting to sky Q box
Which steps?
Message posted on 20 Sep 2023 08:11 PM
Turning off the router and then pressing the button on the router to reconnect it
Message posted on 20 Sep 2023 08:12 PM
Do a full network reset on the Q
Message posted on 20 Sep 2023 08:14 PM
How is that done please?
Message posted on 20 Sep 2023 08:16 PM
Done all of the steps above and still not working correctly.
works for about 30 minutes and then all sky mini boxes lose connection to internet. No more apps available.
beem happening for about 3 weeks now
fed up of it
Message posted on 20 Sep 2023 08:16 PM - last edited: 20 Sep 2023 08:17 PM
Hi @AO21
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 20 Sep 2023 08:18 PM
That's what I've tried multiple times but I hasn't worked. Will have to phone them was hoping to avoid that option
Message posted on 20 Sep 2023 08:19 PM
Are you sure that you are pressing the WPS button on the router and not the reset button.
WPS button shown below
Message posted on 20 Sep 2023 08:21 PM
@Tiredofthis1 wrote:Done all of the steps above and still not working correctly.
fed up of it
Yep. As I always say - use ethernet.
Message posted on 20 Sep 2023 08:22 PM
Yep pressed and held it how long do you need to leave it held down for? Just says searching with a circle going round in the tv screen then eventually says not connected.
Message posted on 20 Sep 2023 08:25 PM - last edited: 20 Sep 2023 08:25 PM
And was this after you carried out the Network reset on the main Q box?
It was yes. It's driving me insane
Message posted on 20 Sep 2023 08:31 PM
Powerline ethernet.
Message posted on 21 Sep 2023 11:33 PM
Exactly the same problem here, all other devices connect immediately but not the SKY box to the SKY router 😡.
Tried everything suggested on here, nothing works. Crap service.
