Discussion topic: Broadband WiFi after numerous attempts of restarting
This message was authored by: Lezz1
My Sky Q Box is not getting connected to my Sky Broadband WiFi after numerous attempts of restarting and resetting the sky box, modem , please advise what can be done to fix this problem
This message was authored by: Greenfingers001
Re: Broadband WiFi after numerous attempts of restarting
Hi there @Lezz1 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Lisa-P1987
We are still looking to help you @Lezz1 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Hi @Lezz1
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Avatar for Lezz1
Hi Oldfella, thanks a lot , had tried the mentioned steps with a Sky customer service agent and have done it few mins back too again, no luck, still cannot connect to Broadband wifi, both devices are about a metre apart, dont see why would i need a Sky booster as prompted when could not reconnect, seems to be a Sky Q box issue, have booked an appointment and hopefully should get sorted
Hi @Lezz1
If your Sky Q box and Q router are only one metre apart why don't you use Ethernet???
