Discussion topic: Brief, intermittent loss of Sky Q output
This message was authored by: FredMel
Hi, our Sky Q box exhibits an annoying, intermittent problem characterised by a brief drop of output to our TV. The duration is no longer than 2-3 seconds and is a loss of output, NOT of satellite signal. This only occurs with the Sky Q box, our blu-ray player output is not afflicted by this problem.
We've tried all the suggestions on the Sky site (reboot, software update, etc.) but to no avail. We've also changed the hdmi cable, each time using high quality 2.1 compliant connectors, and the input port once. Any help or additional suggestions would be much appreciated.
Avatar for FredMel
Level 2 icon
Re: Brief, intermittent loss of Sky Q output
Meant to add that the dropout is sound and vision simultaneously & we changed hdmi cables twice.
This message was authored by: hifiman2007
I'm having exactly same issue. I think the boxes are nearing end of useful life and maybe not compatible with modern tvs
Avatar for FredMel
Level 2 icon
Interesting. I'm actively considering dropping Sky, especially if they start switching to streaming only.
I think they will switch satellite of around 2027/8. Falling out the sky I read and too expensive to launch another
@hifiman2007 It will be after 2029 as Sky signed a contract extension  with SES for satellite use until 2029
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
I did say around😀. Still dissapointing as streaming live TV...can be problematic and revising facilities are very useful
Avatar for FredMel
Level 2 icon
I've had a suggestion from another forum that the problem may be with my Samsung TV. He suggested removing the aerial input & switching off HDMI+ on all inputs. Apparently this is a known problem on Samsung tvs. I'll report back if this works.
Avatar for FredMel
Level 2 icon
Unfortunately, changing the Samsung settings didn't work. Heigh-ho, I'll try a few other things before attempting to contact a human at Sky.
