Discussion topic: Box won’t connect to broadband router
This message was authored by: Squizz
Broadband router won't connect to sky q box
Re: Box won’t connect to broadband router
Hi @Squizz
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
