Discussion topic: Box saying we have withdrawn service on Sky Q box
Message posted on 22 May 2024 06:12 PM
Box replaced on Monday, experienced CRF form having to be raised. Was told could take 1-3 days. Had channels on Monday but went off at 8pm Monday & can't get any channels.
Message posted on 22 May 2024 06:21 PM
Re: Box saying we have withdrawn service on Sky Q box
Hi @TEvans
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 22 May 2024 06:41 PM
Hi,
thanks for your reply. I have tried all of this with no success.
thinking it may take the full 3 days??
Message posted on 28 May 2025 03:36 PM
Hi. I have reconnected to sky but can't get it to tune anything
Message posted on 28 May 2025 03:39 PM
Help to reconnect
Message posted on 28 May 2025 03:41 PM
@TEvans When you originally left sky did you return the Q hardware as you should be sent new hardware if you have returned
Message posted on 28 May 2025 04:52 PM
@Skye31 wrote:Hi. I have reconnected to sky but can't get it to tune anything
There is no "tuning" involved with Sky Q???
