Discussion topic: Box not working properly, won’t play the channels I want to watch when I want also won’t record anyt
Message posted on 12 Sep 2024 05:54 PM
Struggles to play channels and will only play one channel and that's it, will only tape 1/2 a programme because it buffers for the other 1/2 so the channel is then basically paused. Permanently comes up with technical issues or limited service
Message posted on 12 Sep 2024 05:59 PM
Re: Box not working properly, won’t play the channels I want to watch when I want also won’t record
@Robert6367 Have you tried rebooting your Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Sep 2024 07:36 PM
Hi @Robert6367
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
