22 Aug 2024 11:44 AM
Bought single QSky box off sky. Will not work when another box is in operation. Says too many boxes in operation ?
22 Aug 2024 11:48 AM
Posted by a Superuser, not a Sky employee. Find out moreYou haven't bought any Sky Q boxes. They are only loaned to you.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
