Discussion topic: Both my sky q boxes have lost connection with the broadband I have don’t everything , resetting etc
Message posted on 03 Apr 2024 10:17 PM
Both Sky Q boxes have lost connection with the broadband. They were connected. Have tried all the setup etc resetting and nothing is working. Can anyone help ?
Message posted on 04 Apr 2024 09:46 AM
Re: Both my sky q boxes have lost connection with the broadband I have don’t everything , resetting
Hi @Krae
First try to get the main Q box connected.
Start with resetting your broadband router.
