Discussion topic: Booster box not showing as connected. 3 lights but only outer two are lit.
This message was authored by: Kongwa
Have a Sky Q box and a mini box in separate room. Booster box in the middle plugged in and power on but the connected light not showing green.
Re: Booster box not showing as connected. 3 lights but only outer two are lit.
Hi @Kongwa
Try first rebooting the booster by disconnecting the power for 30 secs and then reconnecting.
Then try rebooting the main Q box.
To reboot the Q box,  press Standby on your Sky Q remote (if the box responds to the remote), and then switch off and unplug at the mains.
If the booster still does not connect first press the WPS button on the booster and then press the WPS button on the main Q box.
This message was authored by: Shanthi+Pragasam
In sky booster connection light isn't on after using smart BT hub Thanks
@Shanthi+Pragasam the Sky booster won't connect to your BT hub it needs to connect between your Q box and the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: LynneMeagher64
I've followed all the instructions from the tv but nothing has changed the booster still only showing two lights
Can you give more background? What broadband provider and did it ever work?
Sky is my provider. The booster stopped working about 2 weeks ago. My Wi-Fi works on everything else but just not the tv with main sky box and the tv with mini box. I can still watch sky but can't use demand, catch up or any of the apps
This message was authored by: Buryfc
Yes only outer two are lit on booster box
This message was authored by: TheGallops22
I have the same issue. Booster stopped working about 2 months ago. Only the two out green lights are on.  Sky mini Q won't work
I've the same problem
Have you tried resyncing via WPS ?
This message was authored by: Chandra
Sky booster not connecting to mini box
I have been trying to fix the problem but have not ducceeded
please book engineer
@Chandra Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Have you tried ppressing the WPS button on the booster then on the mini box
This message was authored by: Jose13
I had this exam same issue and couldn't find any helpful advice, in the end I had to connect to the router (192.168.0.1) username: admin, password: (on the back of box. Then go into advanced settings - WiFi - WPS connection. Click the ADD  button and then the WPS button on the extender and it should connect (eventually!) Good luck!
