Discussion topic: Booster box not showing as connected. 3 lights but only outer two are lit.
Message posted on 29 Mar 2023 03:48 PM
Have a Sky Q box and a mini box in separate room. Booster box in the middle plugged in and power on but the connected light not showing green.
Message posted on 29 Mar 2023 04:28 PM
Re: Booster box not showing as connected. 3 lights but only outer two are lit.
Hi @Kongwa
Try first rebooting the booster by disconnecting the power for 30 secs and then reconnecting.
Then try rebooting the main Q box.
To reboot the Q box, press Standby on your Sky Q remote (if the box responds to the remote), and then switch off and unplug at the mains.
If the booster still does not connect first press the WPS button on the booster and then press the WPS button on the main Q box.
Message posted on 03 Sep 2023 09:15 AM
In sky booster connection light isn't on after using smart BT hub Thanks
Message posted on 03 Sep 2023 11:27 AM
@Shanthi+Pragasam the Sky booster won't connect to your BT hub it needs to connect between your Q box and the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Sep 2024 11:06 PM
I've followed all the instructions from the tv but nothing has changed the booster still only showing two lights
Message posted on 15 Sep 2024 07:46 AM
@LynneMeagher64 wrote:I've followed all the instructions from the tv but nothing has changed the booster still only showing two lights
Can you give more background? What broadband provider and did it ever work?
Message posted on 15 Sep 2024 09:07 AM
Sky is my provider. The booster stopped working about 2 weeks ago. My Wi-Fi works on everything else but just not the tv with main sky box and the tv with mini box. I can still watch sky but can't use demand, catch up or any of the apps
Message posted on 08 Nov 2024 01:01 PM
Yes only outer two are lit on booster box
Message posted on 27 Dec 2024 08:43 AM
I have the same issue. Booster stopped working about 2 months ago. Only the two out green lights are on. Sky mini Q won't work
Message posted on 27 Dec 2024 08:49 AM
I've the same problem
Message posted on 28 Dec 2024 07:58 AM
Have you tried resyncing via WPS ?
Message posted on 28 Dec 2024 02:32 PM
Sky booster not connecting to mini box
Message posted on 28 Dec 2024 02:34 PM
I have been trying to fix the problem but have not ducceeded
please book engineer
Message posted on 28 Dec 2024 04:00 PM
@Chandra Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
Have you tried ppressing the WPS button on the booster then on the mini box
Message posted on 25 Jul 2025 06:05 AM
I had this exam same issue and couldn't find any helpful advice, in the end I had to connect to the router (192.168.0.1) username: admin, password: (on the back of box. Then go into advanced settings - WiFi - WPS connection. Click the ADD button and then the WPS button on the extender and it should connect (eventually!) Good luck!
