16 Dec 2023 08:18 PM
After I've been watching a channel for a while and turn to another channel, the tv screen goes black and no matter what channel I select, it still remains black. I can access the tv guide etc but not picture. The only way I can rectify this is to power the sky box off at the wall and reboot. I wouldn't mind but this happens two or three times a day.
16 Dec 2023 08:20 PM
Hi @Pil+wilks
16 Dec 2023 08:24 PM
Thank you, I will try that
