Discussion topic: Bird Spikes directly on Satellite Dish
Message posted on 30 May 2024 05:35 PM
I have put bird spikes on the arm, but pigeons sit on the actual dish, and drop their mess below. I want to know if I can glue spikes directly onto the dish without causing interference. The spikes are metal, and are on a polycarbonate base
Message posted on 30 May 2024 06:24 PM
Re: Bird Spikes directly on Satellite Dish
Hi @Driveway
as they are metal spikes you should make sure that they are positioned so that they cannot deflect any signal towards the LNB.
Proved they are attached rearward of the dish profile I think they should be OK.
