Discussion topic: Best way to connect my Sony A95l, TV Theatre 9 soundbar, Sky Q 2tb and Firestick
Message posted on 30 Sep 2024 04:31 PM
Hi
Looking for advice on tne best way to connect the following kit to obtain best picture and sound quality :
Sony A95L TV which has one 2.1 HDMI Port, two 2.0 HDMI Ports and Optical
I also have a 2.1 HDMI cable
thanks in advance
Message posted on 30 Sep 2024 04:58 PM
							Re: Best way to connect my Sony A95l, TV  Theatre 9 soundbar, Sky Q 2tb and Firestick
@stephen+roach wrote:
Hi
thanks in advance
I am not 100% if the Soundbar has a sperate HDMI port to the eARC connection but I don't think that will necessarily matter (unless you find you get Lip Synch problems which I don't think most people get with newer TVs these days)
Thus the connection from your TV to the Soundbar should be the ones labelled eARC
Neither the Firestick or SKY Q need HDMI 2.1 (only 2.0) so you can connect any device to any of the other HDMI ports
Message posted on 30 Sep 2024 06:47 PM
Thanks nigea66
i will follow your recommendations
