Discussion topic: Best telephone number to speak to the technical department
This message was authored by: Deborahbryan
Tried everything to get my mini box to work
 broadband and sky box connected but still cannot watch anything and remote is stuck
Re: Best telephone number to speak to the technical department
Hi @Deborahbryan
Reboot the mini as above.
If you had to press the mini standby button on the front of the box to switch it on
then Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
