Discussion topic: Best connection to Sky's Soundbox.
This message was authored by PetePP This message was authored by: PetePP
Ive a new LG C3 OLED and have a couple issues.
Ive split my HDMI from  my 1Tb (Has UHD) skyQ box to the LG and another TV but can only receive HD  on both not UHD on LG.. When i disconect other TV and bypass Soundbox all is fine and receive UHD. Any thoughts or will i need a 2nd Mini hub to old TV?
Whic is best - LG HDMI  ARC to soundbox, LG Optical to Soundbox or Optical direct from SkyQ hub to soundbox?
This message was authored by Chodley This message was authored by: Chodley
Re: Best connection to Sky's Soundbox.
HDMI arc to soundbox. Same quality and a single cable.
This message was authored by best+of+the+best This message was authored by: best+of+the+best
Hi @PetePP I have Sky Q connected to Sky Soundbox then Sky Soundbox connected to HDMI 1 on LG tv I don't use HDMI ARC as my Firestick uses that one.
Then optical cable from LG tv into Sky Soundbox for external devices Firetvstick PS4.
No issues with UHD
I think there may be a few expensive splitters that may allow UHD to work with SKy Q but the majority will cause it fail the handshakes needed especially when not all are 4K capable.
Uhfortunately I believe the Soundbox does not have ARC so this may not work.
@PetePP worth reading @mike+simmonds helpful article
Soundbox set up
Soundbox set up
You're kidding me! How does it handle audio for TV content like streaming apps? Optical from the TV?
edit: yeah seems you're absolutely right. What a bonkers decision.
This message was authored by mike+simmonds This message was authored by: mike+simmonds
Morning @Chodley
As @nigea99 says - definitely no ARC with the Sky soundbox and yes, it makes use of the optical output for TV apps.
I've always thought that within its specification, Devialet's build quality of the Sky soundbox is very good- but other than very early firmware upgrades (around 2018) there have never been any upgrades / enhancements.
So it is what it is - no ARC and no way of reproducing Dolby Atmos.
I still use and enjoy mine but it won't do everything some will need it to do.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Probably contributed to its relative lack of success, which led to it dropping from the Sky product line c2020.
Perhaps worth considering that the Soundbox was launched in late 2017, which I think makes it the last product release before the bidding war and Comcast acquisition, and means its development would have been during the attempted Murdoch takeover (which was eventually blocked by UK government) so senior executive attention may have been elsewhere.
https://www.skygroup.sky/article/transforming-the-tv-sound-experience-for-customers-sky-partners-wit...
