Discussion topic: BT Wifi not connecting to Q Box
Message posted on 14 Jun 2024 02:29 PM
Just moved my router to another room following fibre being installed, Q boz was connected via Ethernet and was 100% solid connection. Now via Wifi its either dropping out or seriously slow - whats the solution (other than a long cable!)
Message posted on 14 Jun 2024 05:09 PM
Re: BT Wifi not connecting to Q Box
Hi @Adamppppp
Message posted on 14 Jun 2024 05:13 PM
Yep, done all that when on the phone to Sky. I now have an engineer coming out
