Discussion topic: BT Sports picture
Message posted on 25 Oct 2025 03:33 PM
BT Sports picture
Hi , recently had Sky Q installed and at the same time took BT sport through Sky.
My neighbour has some scaffolding up that is obscuring my dish . The only channel impacted by this is BT Sport.
Possibly all other sky channels are coming throught the internet but BT is through the dish? Is that right and is there a way of changing it?
thanks
Message posted on 25 Oct 2025 03:51 PM
Re: BT Sports picture
Hi @GrahamMiller1 BT Sport, that's a name from the past, I assume you mean TNT Sports. An alternative to watch on Sky is to use Discovery+. TNT Sports is known to be a weak signal, so more likely to be impacted by the scaffolding.
Message posted on 25 Oct 2025 04:18 PM
@GrahamMiller1 wrote:Hi , recently had Sky Q installed and at the same time took BT sport through Sky.
thanks
All live TV channels come via the satellite dish, but as mentioned by @MightyQuinn TNT Sports are the first to be affected by a weak signal.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 25 Oct 2025 04:49 PM
Possibly all other sky channels are coming throught the internet but BT is through the dish? Is that right No and is there a way of changing it? No as all Live channels already cone via your dish so there is nothing to change.
thanks
Message posted on 25 Oct 2025 06:34 PM
ah , understood. , the scaffolding is down Monday so just have to put up with it and will watch footie via SkyGo on computer 👍
Message posted on 25 Oct 2025 07:30 PM
@GrahamMiller1 as @MightyQuinn says you should be able to watch it on the Discovery+ app which is on your Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
