Discussion topic: BT Sport on Sky
This message was authored by: AW22
BT Sport on Sky
I have subscribed to BT sport through BT. They say it's activated but I can only see it on Sky Go, not on my main box. How do I get it activated in my Sky Q box ?
Re: BT Sport on Sky
Hi @AW22
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for AW22
Re: BT Sport on Sky
Hi @oldfella
Thanks for the reply. I've just tried this but no success.
Cheers
Alan
This message was authored by: nstokes
Re: BT Sport on Sky
Have you tried unplugging sky box leaving 2 mins then plugging back in?
Sky Q 2TB, 2 x Sky Q mini
Re: BT Sport on Sky
Also if you have subscribed via BT and not Sky then you shouldnt be able to view BT sport via Sky Go as will need to use BT Sport app
Avatar for AW22
Re: BT Sport on Sky
Hi @nstokes
Thanks I've tried that but still no success.
looks like I'll need to call sky to get to the bottom of it
Re: BT Sport on Sky
@AW22 wrote:
Hi @nstokes
@AW22 If you pay direct to BT for BT Sports doubt there is anything Sky can do about it you would need to call BT as @nstokes says it is very strange that you can watch it on Sky Go as that is normally only available to customers who pay Sky for BT sports
Avatar for AW22
Re: BT Sport on Sky
@nstokes @Laing1
Yes just realised I was still logged in on my son's sky go - I logged out and it's not there
Re: BT Sport on Sky
@AW22 wrote:
@nstokes @Laing1
Yes just realised I@@ was still logged in on my son's sky go - I logged out and it's not there
@AW22 ahh that explains that mystery then 😀
