Discussion topic: BBC standard television is ending soon
Message posted on 26 Jul 2023 03:05 PM
BBC standard television is ending soon.
Software version number 9F0A01.
Upgrade to Sky Q does not work on my television said
installer.
What are my options to keep BBC ?
Message posted on 26 Jul 2023 03:14 PM
Re: BBC standard television is ending soon
@Emmet+John wrote:
Upgrade to Sky Q does not work on my television said installer.
Is that because you do not have access to a Q-compatible satellite dish signal, or because your television set does not have an HDMI port?
Message posted on 26 Jul 2023 05:59 PM
@Emmet+John wrote:BBC standard television is ending soon.
installer.
Software version of what?
Message posted on 26 Jul 2023 07:33 PM
@Emmet+JohnAs far as I know it is only Freesat so with a change to the LNB then Q should work unless you have a communal dish which may have some problems.
Message posted on 26 Jul 2023 07:49 PM
hi @Emmet+John
If you have an old SKY + box that doesn't have HD then you should just be able to look for a second hand SKY HD box on ebay
Message posted on 26 Jul 2023 09:30 PM
That version number mentioned above is for a Pace Sky + box
