Discussion topic: Auto start of next episode
Message posted on 08 Feb 2024 12:05 PM
I'm watching True Detective on Sky Atlantic HD.
Around 10 minutes from the end of an episode the window pops up showing the next episode.
This pop up is obviously appearing too soon. I've asked other people and they have the same issue and suggest it only happens on longer episodes. Anyone else have this problem? Thanks.
Message posted on 11 May 2024 09:47 PM
Re: Auto start of next episode
I am having the exactly same issue whilst watching The Sopranos. It's really annoying.
Message posted on 11 May 2024 09:56 PM - last edited: 11 May 2024 09:57 PM
@Pambro @micum you can go into settings > setup > preferences and turn off auto play next episode which will stop this happening or if its wanting to download the next episode turn off download next episode
Message posted on 11 May 2024 10:28 PM
Thanks, but I don't want to turn it off, I want it sync again.
Message posted on 11 May 2024 10:42 PM
@Pambro I get that but if it's not working properly on longer episodes then it's a work around the other thing you can do is report it to viewer relations although if its software related ie down to the boxes doubt they can do anything if its down to metadata then possibly something they can pass on their e-mail address is viewerR@sky.uk
Message posted on 12 May 2024 07:27 AM
Hi thanks for your reply. Turning off auto start doesnt fix the issue though. I dont want a workaround.
I emailed sky with the details. They said it was likely to be how the sky team had loaded the episodes into the system. It seems to be working ok now.
Message posted on 12 May 2024 07:30 AM
Sometimes the times have been set wrong.
Have in the past when I had Sky Q, emailed the VR team to alert them and they were then corrected.
Send an email to the Sky Viewer relations team to report it;
ViewerR@sky.uk
Message posted on 12 May 2024 08:15 AM
Thank you for your reply. This is the help I'm looking for to get things moving.
I've emailed VR. Thanks.
Message posted on 23 Jun 2024 08:05 PM
Hi
I have the same issue with Brassic. Which email address for sky did you contact please to fix issue.
Message posted on 23 Jun 2024 08:43 PM
@SMSkeeter wrote:
Hi
Message posted on 23 Jun 2024 08:45 PM
Will do.
Thanks Laing1.
Message posted on 04 Oct 2024 11:09 PM
Same issue with The Walking Dead. Just got SKY Q installed and wasn't sure how next episodes work as had SKY HD for the past 15 years. Get a pop up about 15 minutes before the end of the episode and I have to clear it and it never auto plays the next one.
Message posted on 13 Oct 2024 10:38 PM
This started happening to me in last month or so.. actually when I started rewatching Sopranos!
It's really annoying as with 10/15 minutes left it'll appear!
Do we have a fix yet?
Message posted on 24 Oct 2024 04:39 PM
Hi there.
I didn't get a reply to say it had been fixed. I'll check by playing an episode over the next few days and I'll let you know.
Message posted on 24 Oct 2024 04:52 PM
It's still happening! Really annoying 😡
