Discussion topic: Audio description permanently ON on Sky Comedy channel
Message posted on 07 Sep 2024 05:07 PM
Re: Audio description permanently ON on Sky Comedy channel
Hi Folks I had the same problem, and did what modsky suggested, click question mark on the channel and turn AD on instead and the voice over went. Thank Modsky.
Message posted on 11 Sep 2024 02:47 PM
Hi, I've noticed that this problem seems to only exist on Sky Comedy SD - the HD channel is ok!
Message posted on 11 Sep 2024 04:54 PM
Hi
I tried turning AD ON, on the Sky Comedy channel and the voice over did go off! But then it was turned on on every other channel. So annoying.
Message posted on 11 Sep 2024 04:56 PM
Hi, I don't have Sky HD so that won't work unfortunately
Message posted on 16 Jun 2025 09:54 PM
Was there a fix for this? I have it on And Just Like That, it's so annoying
Message posted on 16 Jun 2025 11:18 PM
Hi, no there's no fix and Sky can't or won't help for some weird reason?
Message posted on 16 Jun 2025 11:40 PM
Thanks for replying I downloaded it from catchup and it's fine, very weird
Message posted on 17 Jun 2025 06:31 AM
@oldfella wrote:
@bof wrote:Have the same problem, exactly as described above.
Any solution yet?
Looks like it's nothing to do with the Q box @bof @danbol @aislingdaithi @Ziggy4
It would appear that the channel is broadcasting the Audio Description constantly.
Best to report it to Viewer relations as a channel issue.
Has anyone done this?
Message posted on 17 Jun 2025 07:30 AM
@Bob104 wrote:Hi, no there's no fix and Sky can't or won't help for some weird reason?
Some customers have reported that turning the Audio Description to On when watching the channel actually turns it off.
The channel isn't broadcasting with this turned on, otherwise everyone would see it.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
