Discussion topic: Audio description permanently ON on Sky Comedy channel
Message posted on 22 Jul 2024 05:59 PM
I have a Sky q main box and 3 minis.
When watching the Sky Comedy channel in the last few weeks, I've noticed there is audio description running on the tv shows. This has only started recently.
I've gone into settings numerous times on each box and Audio Description is OFF.
I've pressed the ? Button on remotes and the Audio Description is definitely off.
I've turned Audio description ON and then Off again but the issue persists.
No other Sky channel has this issue.
All boxes have been turned off and on again multiple times and still the same issues.
How do I sort this please?
Message posted on 24 Jul 2024 05:46 PM
							Re: Audio description permanently ON on Sky Comedy channel
Hi
I've noticed the same and it has been driving me crazy. I cannot get rid of it either. Just Sky comedy channel.
Message posted on 24 Jul 2024 07:33 PM
As sorry as I am to hear you are having issues, I'm glad I am not the only one.
I too thought I was going mad.
Hopefully, someone in the know will be along soon enough to offer a solution.
Message posted on 24 Jul 2024 07:47 PM - last edited: 24 Jul 2024 07:48 PM
Message posted on 24 Jul 2024 08:02 PM
Hi thanks for the reply but yes have turned it off on my TV settings and sky settings but it remains on sky comedy channel.
Message posted on 24 Jul 2024 11:13 PM
Audio Description is OFF on settings- accessibility.
Also off on the quick menu (? Button) when watching channel.
No other channels are impacted apart from Sky Comedy.
Checked software version earlier and running the very latest.
Message posted on 30 Jul 2024 01:40 PM
I'm having the same issue, sky comedy only. I've audio description set too off but it hasn't changed it. Any help to sort it would be great 🙂
Message posted on 04 Aug 2024 06:11 PM
Have the same problem, exactly as described above.
Any solution yet?
Message posted on 04 Aug 2024 06:51 PM
Any solution yet?
Looks like it's nothing to do with the Q box @bof @danbol @aislingdaithi @Ziggy4
It would appear that the channel is broadcasting the Audio Description constantly.
Best to report it to Viewer relations as a channel issue.
Message posted on 04 Aug 2024 09:49 PM
Hi All,
I think it's on permanently for some programmes, I've only noticed it for Will & Grace. Still don't know how to stop it though!
Message posted on 04 Aug 2024 10:16 PM
Message posted on 04 Aug 2024 11:49 PM
Ok thanks for that! have sent them an email explaining,
Message posted on 10 Aug 2024 10:33 PM
I just had this happen watching Barry on Sky Comedy, I changed the Audio Description setting on the channel via the ? button to On and it turned off the voice over!
Message posted on 14 Aug 2024 03:52 PM
Hi,
I'm having same issue.
I've just been onto support for the last 30 mins. We did a software update but it has not resolved the issue.
It's really annoying so Sky need to fix this ASAP.
I've emailed the email provided above as well.
Message posted on 14 Aug 2024 07:00 PM
Hi yes it's very annoying, I have emailed the email above too but they just suggested things I tried to do already. I told them those suggestions didn't work. They said its not a Sky issue and that I should call their technical support about it. I said it was a sky issue as other people are having the same issue and why should I go chasing their Tech support, they should call me. They then said they have passed my details onto their Tech support to contact me, that was over a week ago and I've heard nothing. Yet again Sky useless at customer service, which should be better considering the amount they charge for their services!!!
