This discussion topic has been answered Discussion topic: Asks me to subscribe to view channels I already subscribe to.
Message posted on 10 Jan 2025 07:03 PM
Obviously trying to get hold of a living human being at SKY is next to impossible, but I subscribe to a number of channels (e.g. cinema, kids).
When (trying to) access the channels I get the message "to watch this channel please upgrade your subscription".
So basically I'm paying for a service they do not provide. Time to go cable?
Message posted on 12 Jan 2025 01:35 AM
So I finally found the secret well hidden number to ring sky tv directly. And after going through the usual things I'd already done (power down the sky box etc) they fixed it by forcing something from their end. Which obviously would not have happened if I didn't ring them and which they make it incredibly difficult to do.
They are happy to put bills up by inflation busting increases every year, but don't bother to invest in their customer service.
Message posted on 10 Jan 2025 07:04 PM
							Re: Asks me to subscribe to view channels I already subscribe to.
When (trying to) access the channels I get the message "to watch this channel please upgrade your subscription".So basically I'm paying for a service they do not provide. Time to go cable?
Hi @DH16
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
The Sky Q Sports pack and BT Sport if you subscribe through Sky are in HD as Standard.
Sky Cinema if you subscribe is also in HD.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 10 Jan 2025 07:14 PM
Message posted on 10 Jan 2025 07:36 PM
@DH16 wrote:
I was trying to view HD content as I subscribe to Sky Cinema. But no non-HD content works either (eg Nickelodeon). I don’t see a specific “Q HD” subscription pack though in my list of products. But as said do subscribe to SKY cinema. I did make the change in download preferences but doesn’t seem to make a difference.
Hi @DH16
A couple of things to try.
First try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Then reboot your Q box.
Message posted on 10 Jan 2025 07:52 PM
Ok, this might be the issue. My internet (not SKY) is down - or at least only drawing <1 mb/s. Would it be trying to verify my subscription via the internet but be unable to do so. That's the only thing that's "out the ordinary". I already tried the "switch it off and on again" 🙂
Message posted on 10 Jan 2025 07:53 PM
Obviously my internet is functioning enough to post this. So don't really see why it should cause a problem for a one-off check!
Message posted on 11 Jan 2025 08:35 AM
Some internet services are much less latency sensitive than others. Less than 1Mb? Might it be losing packets too?
Message posted on 11 Jan 2025 09:50 AM
@DH16 wrote:Obviously my internet is functioning enough to post this. So don't really see why it should cause a problem for a one-off check!
Watching live TV channels only uses the satellite feed and has nothing to do with your internet.
Can you clarify what you subscribe to?
You mention Sky Cinema, this gives you the Sky Cinema channels (in HD as that's all there is)
You would need the Sky HD Add-on to view the general Entertainment channels in HD.
Nickelodeon could be part of the Kids Add-On, though I'm not too sure about that.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 11 Jan 2025 01:01 PM
Yeah I get I don't watch tv through internet but the programme guide was also not working (or working very slowly) so clearly some things rely on a working internet connection.
I subscribe to Cinema, signature and kids together with multiscreen.
Message posted on 11 Jan 2025 01:04 PM
So not HD? Which would be why you can't view HD content, other than Cinema in HD
Message posted on 11 Jan 2025 04:17 PM
Apologies and thanks for your patience. But to clarify it is telling me I don't subscribe to Sky Cinema (which I do) and also the non-HD Kids channels (which I do).  It's not an HD vs non-HD issue. I'm not expecting to try other HD channels.  And I can see both the basic HD and non-HD channels. Sorry if didn't make that clear and thank you for your patience.
it's clear I just need to ring up sky and cancel my subscription as they are charging me for a product they are not supplying.
