Discussion topic: Asking to press the dot button to connect via WiFi but remote not working
Message posted on 23 Feb 2024 01:35 PM
Sky q mini stopped working, prompted to press the dot on the remote to connect WiFi, button having no impact.
Message posted on 23 Feb 2024 01:39 PM
Re: Asking to press the dot button to connect via WiFi but remote not working
Hi @Ahardy750
Reboot the mini as above.
If you still cannot clear the Step 1 of 4 message
Reset your mini remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to get past step 1 of 4.
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
