Discussion topic: Are all Smart tv.S compatible with sky q
This message was authored by: Lynda+47sp
Buying a new smart tv and looking at Hisense as one option but saw in tv reviews that there are problems with sky q and would have to make adjustments for this. Seems a faff. What should I look out for? Just want a problem free connection
Re: Are all Smart tv.S compatible with sky q
@Lynda+47sp
Avoid 'HD Ready' hardware and only buy a UHD set.  For better HDR compatibility look for a high peak brightness.
A television set working with a Q remote is never entirely guaranteed.
This message was authored by: PeteRG41
You don't have to buy a 4K/UHD TV to work with Sky Q, unless you really want to see 4K/UHS content (for which you'll have to pay more per month).
Pretty much any modern TV will be able to work with Sky, Hisense is a pretty well-regarded make.  If in doubt, confirm with the retailer that the TV you're looking at will be fine with Sky Q.
____
Pete.
