Discussion topic: Arc hdmi cable connected to sky soundbox
This message was authored by: pennydreadful
I have a hdmi cable connected to my Samsung qled tv hdmi arc port and this is connected to my sky soundbox will this be ok (haven't had any issues yet) or should I go back to optical cable thanks
Re: Arc hdmi cable connected to sky soundbox
hi @pennydreadful
Unfrotunately the Soundbox doesn't actually support ARC
You may wish to read this Article that our expert  here @mike+simmonds  has written:
SKY Soundbox Tips
This message was authored by: best+of+the+best
Hi @pennydreadful as the Sky Soundbox doesn't support ARC I don't use the HDMI 2 ARC port by choice my Soundbox is also connected to the tv via optical cable as well for external devices like Playstation and Firetv Stick.
Typically that means you'd get audio from a Q box over HDMI to the Soundbox  just fine: what you won't get is Soundbox audio output from apps on the television, or from any other HDMI device with a television input: those would use the speakers in the TV
