Discussion topic: Apps not working but sky channels are
Message posted on 20 Sep 2023 12:18 PM
Hi,
Since 10.30 last night all the apps on sky are not working ie prime, YouTube, disvoeryplus, paramount, Disney etc. I am working from home and WiFi is working. The box has all green lights so thats not the issue. I can watch TV channels but not catch up or demand.
I have reset, switched off tv at the wall, reset the WiFi box nothing changes.
Message posted on 20 Sep 2023 12:28 PM
Re: Apps not working but sky channels are
@Bell65 wrote:
Hi,
Hi @Bell65
Did you carry out Reset Settings in the hidden menu?
Message posted on 20 Sep 2023 02:14 PM
@Bell65 wrote:
Hi,
@Bell65 Sky had a Major problem with its broadband last night so if you have your broadband by Sky then you could try rebooting your router ie turning it off at the wall for 30 seconds then turning it back on
