Discussion topic: Apps not available on SkyQ box
Message posted on 18 Jan 2025 08:39 AM
Apps not displayed.
I have reset WiFi and
on settings WiFi is ticked.
what should I do now?
Message posted on 18 Jan 2025 08:51 AM
Re: Apps not available on SkyQ box
Have a read through of this Sky help article on fixing app problems on Sky Q;
A couple of things to to try that normally resolves this issue;
First, try a repower of your Sky Q box:
- Press Standby on your Sky Q remote, then switch off or unplug at the mains and wait for the lights on your Sky Q box to turn off.
- Plug in and switch your Sky Q box back on at the mains.
- Wait for the on-screen instructions to disappear then press Home on your Sky Q remote.
Second, try a refresh of your apps:
- Press Home on your Sky Q remote, then highlight Settings
- Press 0,0,1 and Select to access the Installer menu
- Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing.
Message posted on 18 Jan 2025 09:41 AM
Thank you. I have tried resetting apps but it hasn't helped.
I've also noticed that nothing is displayed on HOME screen.
Message posted on 18 Jan 2025 11:59 AM
By the way, the apps refresh, can talk a few hours to refresh.
It does flag this on screen when selecting the Sky Q refresh option.
With you also now mentioning nothing showing on Home Screen, this sounds more like a connectivity issue.
Some questions:
Is this on a Sky mini or a Sky Q main in box?
Do you have a Sky Q booster?
Are you using Sky broadband?
Can you watch live channels and recordings ok?
For yourconnectivity issues:
I know you mention you have a tick on your network and tried a few things.
But just for clarity, work through the following Sky Q connectivity help article first.
If nothing comes to light, come back here for further help.
Message posted on 20 Jan 2025 12:31 PM
All sorted. Thanks
