Discussion topic: Apps better picture and sound Q or TV?
Message posted on 29 Apr 2023 04:10 AM
I tend to use Disney, Apple etc via the sky Q app but I remember someone saying for Dolby atmos and picture qaulity it was better if you used the app on your TV.
Any comments?
Message posted on 29 Apr 2023 07:54 AM
Re: Apps better picture and sound Q or TV?
Any comments?
Hi @Alibali65 It's a matter of personal preference, you will need to try the TV apps so that you can compare for yourself to which one you prefer?
Message posted on 29 Apr 2023 08:32 AM - last edited: 29 Apr 2023 08:43 AM
hi @Alibali65
Personally I always recommend using the TV apps as they are usually set for up the TV, although it might depend on the TV & manufacturer
On Disney plus, Netflix & Prime (so I am guessing Apple but I don't have it) will have the advantage on the TV (or on other devices such as Firestick 4K) of using Dolby Vision which the SKY Q can't do.
Some apps also benefit from having Dolby Atmos on TV & other devices which is not available on all the SKY Q apps - although some do have it (Disney + & Netflix I think but not Prime)
If your TV doesn't suport Dolby Vision or your TV/Sound system do not support Atmos then you probably get similar results on either
