55
This discussion topic has been answered Discussion topic: Apple TV+ no sound on SkyQ
This message was authored by: AKBan
When we turn to the AppleTV+ app on SkyQ, everything works perfectly - except there is no sound at all. Other apps (eg Netflix, iPlayer) have sound, Sky TV channels have sound, and if we switch to the smart TV (a Samsung) it also has sound.
I have checked and the software for SkyQ is up to date. The audio settings are normal, and we have no external speakers or anything like that.
Any ideas?
This message was authored by: Chloe-W22 Answer
Re: Apple TV+ no sound on SkyQ
Posted by a Sky employee
Hey everyone! Welcome to the Sky Community forum, where customers like you are on hand 24/7 (almost) to offer some fantastic advice and help on all things Sky-related.
Unfortunately, we can't replicate this problem at the minute. Can I suggest trying a couple things:
Refresh Apps
Refreshing Apps can take up 24 hrs.
With Settings highlighted press 0 0 1 Select. Select Apps 
Highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
Or, you can also Reset Settings
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by: Oldbexleyboy
I am having the same issue.
Akban, I switched picture quality to SD in Apple TV app settings to get sound back on.
This message was authored by: RaiderStu
I am having the same issue, Samsung TV linked to skyQ box and no sound.
I thought I had solved the issue but switching to SD only worked once. I did contact Sky who asked me to refresh the apps & update the sky software. Unfortunately this only worked the one time. I'm still unable to watch Apple TV thru Sky Q, and have opted to watch it via my Samsung TV app instead. This is really poor support on Skys part.
This message was authored by: Rashb
We're having exactly the same issue. SKY please sort this out!
This message was authored by: trick110
I have had the same issue for months!!  Both Apple TV and YouTube for me.  I have refreshed the apps and reset the Sky Q box and it works once but then back to the same with no sound!!
Needs sorting Sky!!
This message was authored by: Calisseum
I'm having this problem too. No sound in apple tv at all. This was also the case when I used apple tv back in December, so it isn't new.
Please sort it out sky, it's been months.
This message was authored by: Mr+rightxx
I've been having the same issue also looks like they still haven't solved the problem. I tried adjusting the sound numerous times which works once then goes back to normal. I'm able to watch it through my smart tv but why should we need to do this if we have the sky box.
This message was authored by: Sarahn12
Please sort this out sky seems like it's a problem with you not us or our equipment.
I find it odd in all the time this thread has been going that no sky moderators/experts have offered a comment let alone solution ? Appalling ?
@Oldbexleyboy yes if this is supposed to be a sky community page you would think we would get some kind of answer by now.
This message was authored by: Mark2424242424
Same here, when I spoke to sky they stated they had not heard of the problem. I told the operator to google it.
Refresh Apps
Chloe-W22
Yes did all that thanks. Worked once only.
