Discussion topic: Another Sky Q Box suddenly unable to maintain a network connection
This message was authored by: pomkiwi
I have a Sky Q Box connected to a broadband router from another provider via wireless and a couple of mini boxes connected with the aid of a Sky booster.
For the past 24 hours the Sky Q box has been disconnecting from my woireless network. Resetting the network connectionon the Sky Q box results in a functioning connection for a couple of minutes maximum before it disconnects again. I have rebooted my router and my Sky box with no difference. Everything else connected to the router has remained connected as  normal and completely stable.
This happened on and off a couple of years ago but evertthing has been fine since. If I remember correctly the view then was that it was a software/firmware update on the Sky box that was responsible. I find myself wondering if this is the case again especially as there seems to be a number of others having the same issue at the moment.
Re: Another Sky Q Box suddenly unable to maintain a network connection
Not "at the moment" although weirdly they do seem to pop up in batches sometimes, but generally wifi connection issues are absolutely ubiquitous on here.
