Discussion topic: An engineer came and told me I need a replacement skybox. How can I get one
This message was authored by: Philip48
I suddenly could not access my apps on the Tv and the message said I needed to restart the hard disk. An engineer came and tried to restart the hard disk but it would not restart. He said I need a new skybox. How can I access a replacement skybox
Re: An engineer came and told me I need a replacement skybox. How can I get one
@Philip48
Did the engineer not replace it?
@Philip48
I have escalated your post to a SKY support team, who, hopefully, will be in touch - although I am not sure if the support team can directly order one - they should be able to advise.
Please see this link re the escalation and what you might see:
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Avatar for Philip48
No the engineer did not replace it. He was not a sky engineer
@Philip48
So was he a TV repair man and you haven't contacted Sky?
Avatar for Philip48
I'm trying to contact sky now
