Discussion topic: Alternative to Sky Broadband with Sky TV
Re: Alternative to Sky Broadband with Sky TV
@BulletproofQS wrote:
@Chodley
That makes sense. Do you the. Disable WiFi on the minis? I'm assuming that means you can't run them as a booster?
Disabled wifi on all of them.
Correct. As I have the BT disc mesh I don't need the booster feature of the Q boxes.
Avatar for BulletproofQS
This message was authored by: BulletproofQS
@Chodley
Thanks - although I use the wi-fi booster so may have to look at getting some stand alone boosters for the wifi.
@xenon81  do you have Mini boxes as well? That's where my previous issues have came up.
Yes, the mini is linked via WiFi to the main box. For customers like us who aren't on Sky broadband the main box and mini create their own mesh network, so changing from Virgin won't make any difference in that respect, but I haven't had problems with it.
This message was authored by: Cjh23
Hi. Yes you can. I have sky TV and just changed out broadband to Vodafone and once set up it works perfectly.
