Discussion topic: All recordings are not playing and i am unable to download anything
This message was authored by: Nathan50
All recordings are not playing and I am unable to download anything
Re: All recordings are not playing and i am unable to download anything
@Nathan50
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Hi  @Nathan50
You may have a hard drive issue if you also cannot make new recordings.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
