Discussion topic: All my recordings have disappeared
Message posted on 03 Jan 2024 08:29 PM
HELP!!! All my recordings, apart from what I recorded this morning have totally disappeared. I have checked my deleted recordings and that is empty too! I was only 67% full so not at full capacity! How is it possible for every single recording to be deleted?????is there anyway I can get them all back???
Message posted on 03 Jan 2024 08:31 PM
Re: All my recordings have disappeared
Reboot your box in the first instance.
Hi @Cazza4
You could try rebooting your Q box but if this doesn't revive them afraid they are lost.
Message posted on 04 Jan 2024 12:37 AM
Hi Oldfella, thank you so much for responding. I’ve tried rebooting, however its now telling me that it's updating software (for the last 15mins)!! I dare not interrupt, but I'm knackered so going to bed and perhaps try again tomorrow - I'll let you know. Thank you once again.
Message posted on 21 Dec 2024 11:42 PM
What happened when you woke up lol?
Message posted on 03 Jan 2025 02:09 PM
Same thing has happened to me! What is going on?!
Message posted on 05 Jan 2025 04:10 PM
And me.. we have lost everything including all purchases.. this cannot be right and is totally unacceptable.. no warning .. nothing !
Message posted on 05 Jan 2025 04:15 PM
This issue is normally resolved by a reboot. Perhaps reboot your hub first then try
a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 05 Jan 2025 04:54 PM
@Dalmatian66 wrote:And me.. we have lost everything including all purchases.. this cannot be right and is totally unacceptable.. no warning .. nothing !
Hard drives fail like that.
All purchases can be redownloaded.
Message posted on 10 Jan 2025 06:29 AM
It's strange that so many have failed at the same time?
the exact same thing happens to me about the same date. Came here to see if anyone had any luck, it seems not.
Message posted on 10 Mar 2025 09:20 AM
And the same with me.
Saturday the remote stopped working - starting Sky+ took me to the acessibility settings page and couldn't get away from it.
Ordered a new remote and paired it, started Sky, navigates perfectly, but all recordings disappeared, so was it a Sky problem and not a remote one that started it all, or just a coincidence?
Refund for the hassle, expensive Sky?
Message posted on 10 Mar 2025 10:45 AM
@2gigmac wrote:Refund for the hassle, expensive Sky?
What did they say when you asked them?
Message posted on 10 Mar 2025 11:08 AM
I never contacted them, just internetted my way through.
Message posted on 10 Mar 2025 05:08 PM
@2gigmac the fix for the accessibility screen is
to try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
