Discussion topic: All my channels are working all but Channel4 HD what’s wrong?
This message was authored by: Artisanrich
Channel 4HD not working all other channels are good. I have reset the Q box
Re: All my channels are working all but Channel4 HD what’s wrong?
@Artisanrich
What are you seeing when you try to view 104? Any error message?
Avatar for Artisanrich
Yes this channel is currently affected by a problem with your satellite signal
@Artisanrich
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Many thanks
