Discussion topic: All channels and Sky Home screen pixellated. TV on its own is fine
Message posted on 26 Dec 2024 04:17 PM
Message posted on 26 Dec 2024 04:20 PM
Re: All channels and Sky Home screen pixellated. TV on its own is fine
Hi @bossman3155
Could be a Satellite alignment issue.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 26 Dec 2024 04:33 PM
Thank you, I tried that but no good, It happened after I had gone into the Prime Video app. I've tried rebooting. I've booked an engineer, but would prefer to fix sooner.
Message posted on 26 Dec 2024 04:34 PM
Hi @bossman3155
Message posted on 26 Dec 2024 06:33 PM
Of course, but there isn't any workaround for dish misalignment: it's somewhat fundamental that enough signal is received.
Employing a local independent installer gets faster attention, but at a cost (and the risk it's not actually the problem)
Message posted on 26 Dec 2024 06:36 PM
Dish alignment wouldn't cause the home screen to pixelated, just the channels, so this sounds like a different fault. It could be a bad HDMI cable.
