Discussion topic: All 3 of my mini boxes are not working
This message was authored by: Sbishop17
Re: All 3 of my mini boxes are not working
Have you tried a power cycle of the main box?
Hi @Sbishop17
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
