Discussion topic: After storm all 4 of my mimi boxes will connect
This message was authored by: Shani1
All 4 of my mini boxes won't connect to main box since a storm on thursday
Re: After storm all 4 of my mimi boxes will connect
What have you tried so far?
Hi @Shani1
First try rebooting the main Q box and then when this is completely back up and running reboot the minis.  Start with the one nearest to your Main Q box (or if on Sky broadband, Sky router if nearer to the mini than the main box
Reboot the first mini as above.   If it connects move on to the next nearest mini.
If the minis still do not connect try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.   When carrying out Network resets on the other minis you can also use a connected mini if the nearest for WPS.
