Discussion topic: After hard drive reset remotexwint wirk and i cant access anything other than menu
This message was authored by: Ben0F
Message posted on 27 May 2024 04:34 PM
After doing a hard drive reset the box won't work properly and remote won't work. I cant access any recordings or download anything. I cant change channels. Messages staye a technical issue. I've switched the box off and on at the mains and no change
This message was authored by: kop32
Message posted on 27 May 2024 11:10 PM
Re: After hard drive reset remotexwint wirk and i cant access anything other than menu
Hi,
You can try resetting the remote as follows......
1. press and hold 7 & 9 simultaneously until the remote flashes red four times
2. press and hold 1 & 3 simultaneously then follow the on screen instructions.
Back to Sky Q and 2 mini boxes after a failed attempt at Sky Stream (again) , VM 1 gb Broadband and Google Nest WiFi Pro.
