Discussion topic: After fixing NO SIGNAL issue yesterday, now can only access BBC 1.
Message posted on 08 Aug 2024 11:19 AM
Think SkyQ controller not working. Have changed batteries, but still no response apart from sound control working. Cannot change channels or access Apps. How do I get a new remote control?
Message posted on 08 Aug 2024 11:20 AM
Re: After fixing NO SIGNAL issue yesterday, now can only access BBC 1.
@AshBTW
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
In the meantime it may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
Message posted on 08 Aug 2024 11:29 AM
Hi @AshBTW
First try rebooting your Q box?
Then reset your remote control
With the Q box on with green led press and hold 7 & 9 together on the remote until it’s led flashes four times.
Message posted on 08 Aug 2024 01:57 PM
Thank you so much. All sorted. Had to go through several stages to get the signal back yesterday but at no point was there info on re pairing remote controller. Think it wrong that sky customers/users should have to act as Sky Customer Service Department, but thanks again.
