Discussion topic: After an engineer visit we have no signal on any tv
Message posted on 23 Mar 2023 03:55 PM
Message posted on 23 Mar 2023 04:00 PM
Re: After an engineer visit we have no signal on any tv
Have you checked your network settings as the message suggests?
Message posted on 23 Mar 2023 04:05 PM
Yes and I have turned everything off then on again
Message posted on 23 Mar 2023 04:38 PM
We have no signal on our tv following engineer visit to upgrade
We had upgrade to fibre then engineer came and now we have no satellite signal I have followed the instructions on line and on the screen and still nothing is working. I have been trying for a few days
Message posted on 23 Mar 2023 04:43 PM - last edited: 23 Mar 2023 04:45 PM
The upgrade to Fibre would not affect the Satellite Signal
Can you check that the Satellite cables at the back of the SKY Q box are fully connected
BTW I have merged your second post with your original one as people will get confused with 2 separate ones covering the same problem
Message posted on 23 Mar 2023 04:45 PM
Re: We have no signal on our tv following engineer visit to upgrade
Probably best to get a Sky Engineer back @Loraine++Smyth
Message posted on 23 Mar 2023 04:47 PM
How do I contact them?
Message posted on 23 Mar 2023 04:48 PM
Message posted on 23 Mar 2023 04:49 PM - last edited: 23 Mar 2023 04:51 PM
@Loraine++SmythAssuming you also had a router change you will have to set up the main box again so it can connect to the new router.
Here is information on how to set up Q devices if you have changed your router
https://www.sky.com/help/articles/setting-up-sky-q-do-you-have-a-sky-hub
Message posted on 23 Mar 2023 06:15 PM - last edited: 23 Mar 2023 06:16 PM
You have a satellite signal - there's an image in the thumbnail in the top left?
You don't have an internet connection - presumably as others have said because you have a new router with your new fttp connection that you need to re-configure the SkyQ to connect to.
